Finally decided to retire my 8 year old Cooler Master Centurion 590 case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152
I wanted to replace it with something minimalist and bland. I decided to go with an Antec Solo II.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129177
I really like the looks and design of the case. The one down side is the cooling. It's marketed as a silent case so I understand a lot of that design will be terrible for cooling. I also know the lack of side vents and top vents (the top vent is for the PSU) will not create good ventilation.
The way I have it set up now is my Corsair H50 radiator is on the back exhaust slot. It has a fan in front and behind it pulling/pushing air through it. The other 2 fans are on the front. The Antec fan included only pushes ~34cfm. The other ones probably do about 20-30cfm. The 2nd fan came with the Corsair cooler, and the 3rd/4th fan are some Cooler Master case fans that came from another case (~2 years old). None of them are moving much air and I don't have any more fan slots so I figured if I can't cool it with quantity I need to do it with quality.
My GPU temps are are the same, maybe even 1-3c lower. My CPU is 20c+ higher so that probably means that there isn't enough cool air being pulled in. For the time being I have ghetto rigged several more fans in place so the temps are probably only 5c higher than they were (which is still cooler than average).
With my Cm case it didn't matter what fans I got because I had enough room to throw more fans in until the problem went away. With the Antec I need to make good use of the space so I need to pick up some quality fans.
I was looking at getting 2 of these from the front intakes:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608038
and 2 of these to go on my Corsair H50:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
They seemed to be the best I can find that were $30+ or had LED's.
Any comments/suggestions on how I can cool this just a little better?
