is there any guide to do this? i read that there was a pretty good gain in performance in doing this. does anyone have any instructions on how to do it?
The only way that I know of is using replacement O-Ring [which should come with every set of Apogee GT].
You simply put it in place of the stock O-Ring and tighten the screws. It should be enough to bow it [worked for me].
