jonneymendoza
- Sep 11, 2004
Look lads. here is what u do to buy and use a upgraded version of pro:
1. download the win 8 preview/demo
2. install it.
3. load up the upgrade assist and follow instructions on purchasing pro for £25
4.once purchase , download the upgraded files and dump them on a usb stick or whatever
5.install the badboy and it will activate instelf.
DONE
AM i right? is it as simple as that? no need to own any previous copies of windows?
Say if i build a pc tomorrow, no OS on it and the first thing i do is step 1-5. will pro be fully installed and activated legitametly?
edit:
There is one small catch and i will edit my post,
the catch is that if u have to upgrade your hdd or do a reformat and install, you need to do the whole steps again. the issue is this, win 8 preview will run out on feb 2013 so after that, if u want to install win 8 again, u got to get a legit key from a previous version of windows.
2. install it.
DONE
edit:
