I'm using eac3to and mkvmergegui. eac3to says:
So I choose track 1 and track 2 and extract them, then use mkvmergegui to mux them back together, and the final movie still has the subtitles and eac3to still says the track 3 SRT is still there? In mkvmergegui, the SRT is not listed so I can not turn it off or remove it there. Trying to back up my only two DVDs to my htpc, and both have this same problem. If I should use another program, are there any free ones that will take the DVD, remove the subtitles if I choose, and not compress the movie any further?
I know the subtitles are not embedded in the video, because I used a program a long time ago to do this, and the subtitles weren't there, but the video playback was buggy (wmp/wmc aborted half way through the video.)
Code:
d:\software\eac3to423>eac3to.exe d:\Media\splitsecond.mkv
MKV, 1 video track, 1 audio track, 1 subtitle track, 1:30:49, 119.880i
1: MPEG2, 480i60 /1.001 (4:3)
2: AC3 Surround, 2.0 channels, 192kbps, 48kHz
3: Subtitle (SRT)
v01 The video bitstream framerate field doesn't match the container framerate.
