ok, while trying to set up a Linux install on a borrowed Toshiba A10-S157 laptop, i set a blank partition (formatted in Ext3) to active partition through PartitionMagic. When I rebooted... (yes, I know most of you are laughing at me) it says "no operating system found." yeah, well, duh! something in PartitionMagic indicated that setting a Linux partion to active would consequently prompt me to install Linux. Well... it didn't. And now I can't boot to windows either. i'm leaving for greece in 36 hours... and i was hoping to have this laptop dual-booting fedora and XP by the time i leave!! fedora is really only so i can do some WEP cracking IF (and only if...) it's the only way to get online while i'm gone. bad boy, i know...
Cliff Notes
using XP Pro.
Trying to install Fedora
set empty partition to "active"
how do i reset "c" partition to active??
if you need more info, i'll be watching this thread, thanks everyone
Cliff Notes
using XP Pro.
