May 23, 2005 #1 G Gadfly Limp Gawd Joined Jun 16, 2004 Messages 231 The 1T/2T option is not in the neo2's bios, anyone know how to set this timing? I heard someone say to use "A64 Edit" software, but I can not find it Anyone know how to do this? Gad
May 23, 2005 #2 T tsuehpsyde Supreme [H]ardness Joined Oct 22, 2004 Messages 6,604 It should be under DRAM Settings.
May 23, 2005 #3 G Gadfly Limp Gawd Joined Jun 16, 2004 Messages 231 No It is not there, under any version of the bios. (1.3,1.5, 1.4b1 mod, 1.8), not on the neo2 plat. Neo1 plat it is... strange hu?
May 23, 2005 #4 W wonderboy_ Limp Gawd Joined Aug 5, 2004 Messages 184 use a64tweaker: http://home.exetel.com.au/codered/A64Tweaker/A64Tweaker_V031.zip
May 23, 2005 #5 T TheGamerZ Supreme [H]ardness Joined Sep 18, 2003 Messages 5,217 I don't know what you're talking about Gadfly... it IS in the BIOS... ALL versions. Cell Menu > DRAM Settings
May 23, 2005 #6 S SuddenDemise Limp Gawd Joined Feb 21, 2005 Messages 361 I have the Neo2-F and the 1T Timings settings are in: BIOS/Cell Menu/DRAM Config.....I dont see why your not finding it.
May 23, 2005 #7 G Gadfly Limp Gawd Joined Jun 16, 2004 Messages 231 Cause they are not there due to the memory I have (Ocz VX CH-5) Read here: Neo2 Tips and Tricks Everything you could ever want to know about OC'ing with a Neo2.
May 23, 2005 #8 C (cf)Eclipse Freelance Overclocker Joined Feb 18, 2003 Messages 30,027 you have a san diego, right? you'll need an updated bios, as its probably hiding the CMD setting. you'll normally see it just under the ram frequency setting in the memory page
