jonneymendoza
- Sep 11, 2004
Hi all.
is there a guide on what to do to flush my system?
i have 360 ex rad, a pump, res and two blocks for my 480gtx and i7 920 cpu.
i built this just over a year ago and used just clear distilled water. The water is no longer 100% clear and can see some dirt or whatever thats built up. time to flush it out?
i have my pump right at the bottom of my case and can easily take it out and disconnect it so the water escapes from there.
So all i do is just drain it from the bottom, take out all the tubing and then clean or replace the tubes and retached again?
Do i need to clean the blocks? if so how? open and dismantal the blocks and clean inside or no need for it?
What about the rad and pump? do i need to dissmantle and clean those too?
I have some questions about fluids. i may use one of these http://www.specialtech.co.uk/spshop/customer/Fluids--Dyes-cid-1182.html 1lrtre bottles. do they ruin the tubing/bllocks? do i need to flush and clean more frequently due to using Dye's?
How often do u flush your systems?
