That's correct, it's model 530i. I work there and have been eying it up, but I'm not so sure this is a hot deal though. You can get a 16x D/L Lite-on for about the same price from Newegg. Unless HP is really great or something, not sure. Thanks for sharing.pstang said:I went to the HP web page and the omly DL model they sell is the 530i
This drive is an OEM Liteon SOHW-832S
The good:
This drive is a faster and more reliable DVD ripper than other HP NEC based drives. You could use LtnRPC utility to reset or disable the Region Counter (get it in here: http://dhc014.rpc1.org/LtnRPC/). It also supports DVD+R bit setting.
The bad:
After some trial and error we found that this drive is very picky when burning DVD-R media. I tested the same DVD-R media in my NEC-2500 and it worked properly.
The ugly:
According some reviews that I have read, the DVD-R problems also happens with the real Liteon SOHW-832S. No fix is available yet. If you want an HP drive and the capacity to burn cheap DVD-R media get a HP 420n or 520n drive.
ShepsCrook said:Wonder if you could bios flash the 530i into a lightscribe drive.
