mattchapman
- Dec 30, 2005
I currently have been using my regular desktop to play movies on my HDTV. I output video using DVI and audio using SPDIF. I run through my Onkyo TX-SR604 receiver to my 5.1 speaker setup.
My movie MKV files typically have DTS or DD (ac3) sound. Now I was under the impression I was getting the best sound quality possible as SPDIF was digital passthrough. However, after researching my new HTPC build I think perhaps not as it appears DTS-HD and TrueHD are the best these days.
My question is...given my receiver does not appear to support DTS-HD or TrueHD then do I really need to worry about getting a CPU/GPU/MOBO to support that? I was headed toward the cheaper AMD setup but was told i3 is better because it supports DTS-HD or TrueHD...but again I don't think my receiver will even support that.
Thanks
Thanks
