Syphon Filter
- Dec 19, 2003
Chaps,
I'm looking to build an HTPC but am struggling to decide between an AMD APU or an Intel i3. This will likely be an always on unit so I would like to keep the power consumption down.
Secondly, I would be looking at using onboard graphics (iGPU). In terms of video this is fine, I think both the APU/i3 solution will deal with faultless 1080p playback. However, the system MUST support bitstreaming of HD Audio (DTS-HD-MA and DD-THD). Is this down to the CPU I choose or the motherboard capabilities?
Currently I am looking at the following items:
Intel:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-493-IN
http://www.overclockers.co.uk/showproduct.php?prodid=MB-461-GI
AMD:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-356-AM&groupid=701&catid=1967&subcat=1944
http://www.overclockers.co.uk/showproduct.php?prodid=CP-331-AM&groupid=701&catid=1967&subcat=1944
http://www.overclockers.co.uk/showproduct.php?prodid=MB-482-GI&groupid=701&catid=1903&subcat=2230
What's the difference between the A8 and A10??? They're priced the same. Will both the APU and the i3 support bitstreaming of HD Audio over HDMI?
If anyone can offer some advice it would be much appreciated.
Thanks,
sf.
Intel:
AMD:
Thanks,
sf.
