Ok, I have a Gateway E4300 SFF computer I use as my HTPC. Don't laugh, its not a bad little puter and I got it for free. The only change I've done was I bought a Zotec 8400 GS video card to give me HDMI output and use audio port mapping on my tv to get audio from another input. I plan on buying one of the new Ceton Mcard tv tuners when they come out and putting it in this little rig with some upgrades. Here are the current specs and what I plan to change:
Intell P4 3.4 ghz
1.5 gig (2x 512, 2x256) DDR2 800
80gig WD HD
Unknown DVDrom
Windows XP Home
Here is what I plan to upgrade:
Western Digital Caviar Green WD20EADS 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
Microsoft Windows 7 Home Premium 32-bit 1-Pack for System Builders - OEM
The onboard sound actually works decent and has a fiber audio connection which is a plus on such a small system. The only other thing I might upgrade is a blueray player. Wont need a burner as I have several other pc's on my network with good burners and have everything hardwired. With the cost of the Ceton card and upgrades I'm looking to spend about 800.00 for a DVR that can record up to 4 streams at once and stream to all my other pc's and 360. I would add two hard drives but sadly this case has space for only one drive. I'll probably replace the floppy disk drive with a media reader as well, but thats a side thought, not really that important as my tv reads media as well. Also, need to find an obscure 4 pin to 3pin cable to go from my onboard sound digital out to my vid card so I can get audio through HDMI, just haven't spent the time looking yet heh.
I know I would do better to replace the case and power supply to give me more options, but this is really all I need and the case is a perfect fit with how I have my tv setup. So, whatcha think?
Intell P4 3.4 ghz
80gig WD HD
Unknown DVDrom
Windows XP Home
