accidentalsuccess
- Dec 7, 2001
Hey all,
I just installed an E5200 2.5gig x 2 processor. I haven't used intel in quite a while but I am very excited about this processor. However, I had trouble getting the HSF on correctly (but finally did) and my idle temps are ~31C.
I just tried to burn a dvd w/ a program that uses 100% on both cores and the temperature spiked to 69C before I killed the program. That is WAY too high, I'm sure. As I'm typing this the core temp is back to 33C (system is at 32C).
What gives? Do I still have an improperly installed processor (used AS thermal paste w/ the stock HSF. . .had to clean off the orig. stuff after my failed attempt at mounting the HSF)
MB is ASUS P5QL pro, if it matters.
I can play FC 2 for hours and the temp never tops ~45C.
Thanks in advance!
Thanks in advance!
