FingerSlut
- Nov 8, 2002
I spent all day building this computer. The case is a thermaltake v5000, and i painstakingly hooked up all the fans to the "hardcano". The mobo is the abit AN7, with a amd mobile 2500+. Ram is 2x512 corsair xms. Video is 9800 pro. HD is seagate sata 7200 rpm 160 gb. And i dont remember what brand the dvd burner is, but it was moderately priced. The hsf is the volcano 12 "extreme".
Anyway, i kept the cpu underclocked for windows install. I installed all of the windows updates. Installed MS flight sim 2004 and Farcry. I then overclocked modestly and worked my way up to 205x10. Everything ran great. For some reason i cleared the cmos, unhooked everything, moved it across the room to hook up to my bigger monitor to check out the games. No post. 3 beeps and then 2 shorter beeps every time. It gave me a code on the bottom, but it doesnt correspond to anything in the mobo manual. I switched memory positions. Checked the seating of the video card. Checked to make sure the hsf was in the cpu power on the mobo. Then i completely torn the computer down and rebuilt it again. Didnt catch any errors but noticed the cpu now has what seems to be black marks in every hole on the top. I dont remember if it was like that. Also, on top of the shiny cpu part, looks like a square trace of the microprossessor. Didnt remember that either. IS the cpu gone, or should i try psu or mobo swapping?
