I have a hydor L-30 water pump as part of my water cooling setup and it is loud. I can hear it vibrate and rattle when outside of the case. When I put it inside the case, the vibration is amplified and it vibrates my whole case making it louder. When I bought the pump the specs specificly read. Quiet operation. Are all water pumps this way? Am I doing something wrong? Or is it just the Hydor L-30?
The reason I went with watercooling was to have a quiet computer, I do get coolor temps but there's no decrease in noise. The fans are silent. But the pump is still as loud as if I had normal noisy fan cooling.
Would a Zalman reserator solve my noise problems? Can it handle the heat of my CPU and GPU?
