Hey guys, I have the following config so far, but I can't seem to settle on a mobo/RAM combo. Minor OCing would be fine (Ive never done it, so Im not hard core). I prefer stability over OCing ability.
1) Stability
2) SATA
3) On-board audio (this will be a gaming rig nothing more; no need for uber audio)
4) OCing is a nice to have, nothing required
5) NCQ? ( Do I care about this? If so, how do I know a mobo supports it? Is SATA 2 or 300 the tipoff?)
MOBO: DFI LANPARTY UT nF4 Ultra-D ATX AMD Motherboard - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16813136152
$135
CASE: THERMALTAKE Tsunami VA3000BWA Black Computer Case With Side Panel Window - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16811133132
$109
CPU: AMD Athlon 64 3000+ Venice 1GHz FSB 512KB L2 Cache Socket 939 Processor - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16819103536
$149
RAM: CORSAIR 1GB (2 x 512MB) 184-Pin DDR SDRAM Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440
$78
GPU: Rosewill Radeon X800XL 256MB 256-bit GDDR3 PCI-Express
http://www.newegg.com/Product/Product.asp?Item=N82E16814164041
$272
HD: Seagate Barracuda 7200.7 SATA NCQ ST380017AS 80GB
http://www.newegg.com/Product/Product.asp?Item=N82E16822148040
$65
PSU: FSP Group (Fortron Source) AX500-A 500W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817104934
$89
OPTICAL: NEC BLACK IDE DVD BURNER - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16827152035
$49
FLOPPY: NEC FD1231H-302 BLACK INTERNAL FLOPPY DRIVE
http://www.newegg.com/Product/Product.asp?Item=N82E16821152005
$8
TOTAL: $955
1) Stability
2) SATA
$135
$109
$149
$78
$272
$65
$89
$49
$8
TOTAL: $955
