I trashed my PSU today, I was running the following...........
P4 3.2C Northwood @ 3.75GHz 1.60v
1GB DDR400
6800GT @ Stock
3 x 7200rpm SATA HDDs
DVD-R Drive
Waterchill control unit (inc. 2 x 120mm fans)
120mm case fan
plus some other bits
Prime95 wasn't loading the CPU 100% (damned HT) so I decided to run the RTHDRIBL 3D program at the same time. That would load both the CPU and GPU to be a really good stress test. Almost as soon as I started the two tests and the Northy and 6800GT started sucking down the juice like a couple of electro-junkies.............POW!! Instantly I lose the video signal and the PC powers off, no warning, no nothing! It refuses to startup again, a test of the PSU reveals it's dead. The Prime95 test I was running was the new power-demanding torture test. It looks like I simply demanded far more than the PSU's 380W could provide. I've now installed my old Enermax 650W PSU in it's place, that ought to be able to cope!! Everything is working fine again now, things could have been MUCH worse though. PSU death is like Russian roulette for your PC, looks like I got away with it this time.
So, before I try that again, does it sound to you guys like a simple case of overloading the PSU and not something else I should avoid? I think I'll stick to stress testing with the 3D demo on it's own from now on...lol.
1GB DDR400
6800GT @ Stock
DVD-R Drive
120mm case fan
