Well guys I think I really screwed up this time. I was all done placing my order from Danger Den (RBX, Maze 4 GPU, Heatercore, Hydor L35, etc. All with the 1/2" fittings) and the last thing to get was the tubing.
So I went to the tubing section and I see some writing in bold red. It says "3/8" ID Tubing will fit around 1/2" OD fittings."
So in my Uber n00bness I said "ok, they say I should get the 5/8" OD then."
And so without even another thought, I bought 9ft of the Tygon stuff for like $20.
Only now that my order has gotten here (still waiting for some stuff from Frozencpu) that I realize my mistake. They do go on the fittings, but with a lot of effort.
But the big question is, how much is this going to hurt my performance if I stay with it?
And yes I will be overclocking my AMD 2400+ Mobile.
Oh, and even though on the DD site it says that the L35 has a max flow rate of 320Gph it really has 450. Don't know if that matters though.
Damn this sucks...I was really excited about all this too. And the sad part is I don't have enough money to get 9ft of the 1/2" ID tubing I feel like such an idiot. Please help me!
Edit: After doing some Googleing and reading some other stuff in various forums, it turns out that my mistake may not have been as large as I had imagined. Is this true?
I read that 3/8" makes the pressure higher and hardly reduces flow at all. Is this true?
Also, it is really hard to get this tubing on the 1/2" fitting on all the components. Any tips for making it easier?
Thank you for any help that you can give to a poor helpless n00b. : )
