Quick Draw McGraw
- Nov 2, 2004
I was thinking of getting a secondary HDD for data storage (500GB SATA II; running at SATA I on my Asus P4C800 Deluxe but transferable to a SATA II MB in future).
Sometimes I wont need to access the data but once or twice a week and sometimes I will need to access it 8 hours a day.
Its kind of a waste to run it 8 hours a day all week long if I only access the data once or twice during that week and I dont know if its wise to run it 8 hours a day in an external enclosure.
I thought I could hook the 500GB to a USB 2 interface inside my case and mount an external on/off switch, kind of like having an external drive inside my case without the external enclosure.
Think that would work? (over the external enclosure the HDD would have better cooling via my case fans and create less desk clutter)
Or if I hook it up as an internal SATA drive and splice in an on/off switch to its power (from my PSU). And just turn it on when needed.
If when my computer was up and running and I turn on the secondary drive would Windows recognize it (as it does when you turn on an external USB device) or would I need to reboot or is it a foolish idea?
Or is there a way to turn an internal HDD on and off independent from the computer?
