FoxhoundOp
- Apr 26, 2003
Casual gaming, typing papers, etc
I don't really want to spend more than $450.
3) Where do you live?
MI 48037
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Motherboard, ram, videocard, power supply
Case, WD Caviar 320GB, DVD drive
6) Will you be overclocking?
Yes.
1280 x 1024 POS for now, plan on upgrading to 1920 x 1080 here soon
Within the next week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing in particular. Just want something capable of overclocking nicely. Looking to hit 3.8Ghz or so.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
I've got a wishlist that I'm pretty much set on but I want to run it by you guys to make sure I don't miss out on any good deals. I bought an i5 750 from Microcenter for $160 so I'm set on that, just need the other goodies.
CPU: Core i5 750 http://microcenter.com/single_product_results.phtml?product_id=0317379
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
GPU: XFX HD-477A-YDFC Radeon HD 4770 512MB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Motherboard: ASUS P7P55D LE LGA 1156 Intel P55 ATX Intel Motherboard - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16813131410
PSU: Antec EarthWatts EA650 650W http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
The wishlist doesn't include the CM Hyper 212+ that I plan on buying from Microcenter for $25
MI 48037
Yes.
Yes
