BillParrish
- Aug 25, 2006
My ongoing investigation finds the Uncore portion of an i7 draws it's power from the +5 from the main motherboard connector for the onboard memory controllor and power from the 3.3V for the QPI.
I was reading this http://www.lostcircuits.com/mambo//index.php?option=com_content&task=view&id=44&Itemid=1&limit=1&limitstart=2
and it occured to me to wonder how it would affect power supplies for new i7 builds or upgrades, (somewhat astonished some power supply makers did not jump on their products with solid +5 as "i7 friendly" or some such rubbish, Guess its a bit over the heads of most marketing types. )
Intel recommends for their own X58 board (and of course the do not consider any OCing when stating their specs/recommendations)
The power supply must comply with the indicated parameters of the ATX form factor
specification.
The potential relation between 3.3 VDC and +5 VDC power rails
The current capability of the +5 VSB line
All timing parameters
All voltage tolerances
For example, for a system consisting of a supported 130 W processor (see section 1.4
on page 14 for a list of supported processors), 1 GB DDR3 RAM, one high end video
card, one hard disk drive, one optical drive, and all board peripherals enabled, the
minimum recommended power supply is 460 W. Table 24 lists the recommended
power supply current values.
Table 24. Recommended Power Supply Current Values
Output Voltage 3.3 V 5 V 12 V1 12 V2 -12 V 5 VSB
Current --------22 A 20 A 16 A 16 A 0.3 A 1.5 A
My point is that it now seems that it is no longer all about the +12. Most high performance supply's should have sufficient +5 and +3.3 but I have found a few less powerful/expensive ones that are marginal or do not. While Intel recommends at least 20A on the +5 and 22A for the +3.3 for their own X58 board I would want more and I would want it to be clean and just as important would want to know how did loading up the +12 affect the voltage regulation and noise on the +5 and +3.3
I highly recommend that people recommending supplies for i7 systems go back and look at the quality (noise, ripple, regulation) of the +5 and 3.3 of a supply before recommending it for an i7 machine.
Disclaimer: As mentioned my investigation is not complete as there are no new VRD specs from Intel and Motherboard manuf do not bother to provide sufficient technical details of there board designs but Intels own specs and reviews around the web where i7 CPU power requirements that where determined only by measuring the current flowing through the 4 or 8 pin aux 12V power that feeds the CPU VRD (aka VRM) are wildly incorrect supports my preliminary conclusions. There also seem to be a lot more components not near the cpu on X58's that look like VRMs than I am used to seeing.
specification.
