gimilthedwarf
- Dec 30, 2002
Hi,
I'm getting a new laptop that will be used for college.
I've narrowed it down to 2 laptops, the IBM T42p and the IBM X40.
From what I can tell the T42p will be MUCH faster, but the battery life will be lessoned and it is heavier then the X40.
But the X40 is much smaller, lighter, and has a longer battery life.
Battery life is very important to me b/c I will be using it on the go a lot. But I'd also like soemthing fast enough to get the job done in most situations.
Give me your thoughts on which laptop i should get of these two or if there is another laptop i should be looking at.
Thanks
Thanks
