I left my PC on doing IBT tests overnight and turned it on this morning to an error message. However, it looks like the failed run has a massively different value to what it expected (moreso than I've seen in previous failures) and I also realised that the time of failure would have been very close to when I woke the PC up (see the log below). So my question is, could a bug have caused this error to occur when I shook the mouse or whatever to see what the result was rather than it actually failing after 76 (!) passes?
Code:
IntelBurnTest v2.3
Created by AgentGOD
Processor: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Clock Speed: 3.70 GHz
Active Physical Cores: 8
Total System Memory: 6135 MB
Stress Level: Maximum (4364 MB)
Testing started on 14/07/2009 00:10:34
Time (s) Speed (GFlops) Result
[00:16:16] 319.558 26.5868 2.905686e-002
[00:22:09] 332.061 25.5857 2.905686e-002
[00:28:15] 344.348 24.6728 2.905686e-002
[00:34:30] 353.262 24.0502 2.905686e-002
[00:40:37] 345.795 24.5695 2.905686e-002
[00:46:41] 342.469 24.8081 2.905686e-002
[00:52:18] 315.916 26.8933 2.905686e-002
[00:58:45] 365.544 23.2421 2.905686e-002
[01:04:20] 313.840 27.0712 2.905686e-002
[01:09:55] 313.552 27.0960 2.905686e-002
[01:16:08] 351.125 24.1966 2.905686e-002
[01:22:34] 365.485 23.2459 2.905686e-002
[01:28:46] 349.856 24.2843 2.905686e-002
[01:35:02] 354.810 23.9453 2.905686e-002
[01:41:21] 358.269 23.7141 2.905686e-002
[01:47:40] 357.803 23.7449 2.905686e-002
[01:53:46] 343.919 24.7035 2.905686e-002
[02:00:09] 362.450 23.4405 2.905686e-002
[02:06:31] 359.450 23.6362 2.905686e-002
[02:12:49] 356.689 23.8191 2.905686e-002
[02:18:50] 339.639 25.0148 2.905686e-002
[02:24:59] 348.559 24.3747 2.905686e-002
[02:31:18] 357.587 23.7593 2.905686e-002
[02:37:37] 357.605 23.7581 2.905686e-002
[02:43:31] 332.389 25.5604 2.905686e-002
[02:49:42] 349.355 24.3192 2.905686e-002
[02:55:46] 342.817 24.7830 2.905686e-002
[03:02:09] 361.681 23.4904 2.905686e-002
[03:08:28] 357.798 23.7453 2.905686e-002
[03:14:25] 335.655 25.3118 2.905686e-002
[03:20:55] 368.355 23.0648 2.905686e-002
[03:27:19] 363.448 23.3762 2.905686e-002
[03:33:55] 374.895 22.6624 2.905686e-002
[03:39:55] 338.463 25.1018 2.905686e-002
[03:45:20] 303.143 28.0264 2.905686e-002
[03:51:42] 360.205 23.5867 2.905686e-002
[03:58:00] 356.479 23.8332 2.905686e-002
[04:04:31] 370.255 22.9464 2.905686e-002
[04:10:28] 335.793 25.3014 2.905686e-002
[04:16:36] 346.181 24.5421 2.905686e-002
[04:22:26] 329.068 25.8184 2.905686e-002
[04:28:16] 329.185 25.8092 2.905686e-002
[04:34:15] 336.910 25.2175 2.905686e-002
[04:40:28] 351.595 24.1642 2.905686e-002
[04:46:33] 343.688 24.7202 2.905686e-002
[04:52:28] 333.852 25.4485 2.905686e-002
[04:58:38] 349.093 24.3374 2.905686e-002
[05:04:29] 329.657 25.7723 2.905686e-002
[05:10:45] 354.023 23.9985 2.905686e-002
[05:16:43] 337.432 25.1785 2.905686e-002
[05:22:55] 350.828 24.2170 2.905686e-002
[05:28:56] 339.467 25.0276 2.905686e-002
[05:35:25] 367.750 23.1027 2.905686e-002
[05:41:28] 341.426 24.8839 2.905686e-002
[05:47:16] 326.233 26.0428 2.905686e-002
[05:53:26] 348.712 24.3640 2.905686e-002
[05:59:40] 352.803 24.0815 2.905686e-002
[06:05:52] 350.540 24.2370 2.905686e-002
[06:11:56] 343.011 24.7689 2.905686e-002
[06:18:15] 357.180 23.7864 2.905686e-002
[06:24:11] 335.147 25.3501 2.905686e-002
[06:30:07] 333.919 25.4434 2.905686e-002
[06:36:18] 350.188 24.2613 2.905686e-002
[06:42:11] 331.455 25.6325 2.905686e-002
[06:48:23] 350.926 24.2103 2.905686e-002
[06:55:03] 378.046 22.4735 2.905686e-002
[07:01:27] 362.699 23.4244 2.905686e-002
[07:07:26] 337.848 25.1475 2.905686e-002
[07:13:32] 344.388 24.6699 2.905686e-002
[07:19:45] 352.026 24.1347 2.905686e-002
[07:25:57] 350.144 24.2643 2.905686e-002
[07:32:16] 358.587 23.6930 2.905686e-002
[07:38:25] 347.560 24.4448 2.905686e-002
[07:44:53] 366.878 23.1576 2.905686e-002
[07:50:52] 337.575 25.1678 2.905686e-002
[07:57:20] 366.562 23.1776 2.905686e-002
[08:03:31] 349.745 24.2921 1.471042e-001
Testing ended on 14/07/2009 08:03:31
Test Result: Failure.
