RyanLucier
- Nov 23, 2006
So... Sitting in my office right now with very little motivation to work Taking a 30 minute break and I'm thinking to myself, why do we not have something better than the registry. Here's what I was thinking, why doesn't windows scan all root folders in "c:/program files" looking for a specific registry file that it loads.
This would allow you to quite literally drag-and-drop programs into program files and they'd be installed automatically & quickly. Dependencies could be indicated in the registry file of the root folder of each individual program as well, and if the dependencies were not installed they could be installed/downloaded.
Is it just me or does this not sound like a far superior system? You could literally bring your PC back to a "fresh install status" by just removing every folder in program files.
I highly doubt the bootup scan process would add much time to bootup either, as it would just scan the root folder of each folder in c:\program files and look for a specific file (similar to autorun.inf on CD/DVD's). I bet 500 folders could be scanned practically instantly, and I doubt many users have over 500 programs installed. But even if they did, the additional bootup time would probably be negligible.
This would also eliminate programs nuking operating systems.. Say you installed something which prevented the OS from starting, just bootup on a USB thumb drive or something and delete the offending folder. Problem solved?
Thoughts/opinions?
Thoughts/opinions?
