I'm going to be building a watercooled setup and I'd like to get some suggestions from the community.
I love the design of the Lian Li V1000 case, and I think it would be perfect for the water cooled setup I'd like to try. However, there are a few snags I'm hitting.
1. I want to mount the radiator (Black Ice II) on the top of the case. I'm worried that there won't be enough room due to the fact that I have never seen anybody do this before.
2. Will there be enough airflow into the case for me to mount the radiator internally?
I used Google's SketchUp and some pre-made models to see if everything would fit...
With waterflow (the order and exact positioning of things will probably change):
Everything seems to fit according to the model, but I want to make sure it will all be perfect before I drop $200 on a case that won't work.
