black_b[ ]x
- Jul 1, 2002
Built my first WC setup 3 years ago, trying to decide where to go for my next build and would like comments on the layout.
Coolermaster Stacker case
Danger den D4 pump (older noisier one)
DD dual radiator with DD shroud and extra cardboard standoff
RBX waterblock, drilled to fit an evga 6800 ultra
TDX for A64
PVC pipe reservoir
1/2" ID tygon tubing
The pump is in the front of the case and the direction is pump->rad->GPU->CPU->reservoir->pump
No kinks or real sharp bends and the paths seemed straightforward at the time. I made the vents/holes in the bottom of the case larger to fit the radiator. I also have a cardboard shroud on top of the radiator fans to direct the air over the northbridge, which unfortunately is right below the video card. I think air cooling the NB on a socket 754 was a mistake, it got quite hot and i think it was my limiting factor for OC'ing.
1) how much of this can i safely re-use? I'll probably build a core 2 in the near future.
2) Any suggestions on where/how to add a drainage port? I tried a T-fitting with a plastic valve from ace hardware and it dripped badly.
3) The pump is whiny, but tolerable. Is there any market for selling a 3 y/o water pump? its only seen nighttime and weekend use.
4) any other suggested changes? junk it and start over with a new case?
5) should I move the radiator so I can put in a 2nd PSU for the pump and fans? I think this setup killed my 550w fortron PSU recently.
TDX for A64
PVC pipe reservoir
