x86:
http://download.microsoft.com/downl...82-84DD-C46C46C6FE50/IE9-Windows7-x86-enu.exe
x64:
http://download.microsoft.com/downl...82-84DD-C46C46C6FE50/IE9-Windows7-x64-enu.exe
The x64 is for x64 OSes, and it installs x86 and x64 versions of IE9 RC.
I installed it a while ago, all the sites I tried worked perfectly, and it has new features like tracking list and activex filtering.
Tracking lists allow you to disable tracking from web sites that track your web browsing..
Active-X filtering allows you to enable/disable active-x controls on a per page process, it's an improvement over active-x approved domains and regular active-x prompting as you only have to enable it once per site and all controls load, instead of having to click OK to many different active-x controls per page with the previous method. And when you're done you can select disable to disable all active-x controls again, or just leave them enabled for that web page. Pretty nice for the security conscious.
The browser GUI now has square browser tabs (which look nicer than they sound) and the ability to put tabs below the address bar if you're the type to have many tabs open.
Enjoy. (please no "I don't use IE" etc. posts, make your own thread.)
x64:
