spydermonkey
- Nov 30, 2004
So I decided to get back into folding now that my rig's up and running again, and wanted to have both cores folding. I tried using the SMP client, but I'm having some problems with that, so I'm trying to use two F@H clients with the affinity of each set to a different core. I start the clients with the -local switch, and set the affinity in the task manager. I also have each set to a different machine ID, but when i look in the task manager, I see that each client is only using 35% of the CPU usage (set in config to 75% idle) Does anyone know if I'm doind something wrong?
Other than that, the GPU client's working fine.
