Trekari said:It is incorrect to say the 215TW does not support 720p through the component inputs.
I purchased one 12 days ago from Best Buy and since I was concerned about this report and wanted to know if I should hustle to return it within my 14 day period, I hooked my 360 up to the monitor just now.
Initially it was 480i stretched to fit the screen, since I still had my selector on SDTV, but when I moved it to HDTV the Xbox rebooted and came up in 480p. At that point I went into my dashboard and selected 720p as the resolution I wanted to use, since we all know the 215TW cannot support 1080i natively. Indeed my Xbox set the resolution to 720p and i checked the menu of the Samsung to verify this and it reported that the resolution it was receiving was 1280x720 @ 75Hz.
However bear in mind that since this monitor has no support for hardware centering of the display, it does indeed stretch it out a bit to fill the screen to it's native size.
Hope this clears that up. I am very satisfied with mine.
yeah even though it does stretch the aspect ratios are very close so the stretch effect isnt as bad as say using 1280x1024.
