Waiting for the jailbreak...
From the point the download finished to the time my phone had rebooted back to the home screen, it was about 20 minutes.
And already jailbroken and unlocked
I was pissed enough to make this, which sums up my feelings on iOS4...
http://i58.photobucket.com/albums/g243/pnut12345/automotivator.jpg
eh... multitasking isnt really multitasking at all. All it does is you don't have to go back to home screen to run another app that you want to use. It doesn't seem like it save the state of the app you're in.
For instance, I run Bookworm game to play, then I double click on the home button to bring up the multitasking menu, I choose to look up an address on the map. After I'm done, I double click on the home again and pick Bookworm, thinking I just resume where I left off. Low and behold, Bookworm has the load again as if I just ran it the first time.
That's my 5 mins with the IOS4 so far, gonna keep playing with it.
Apps have to update to specifically support multitasking, because there's a new API involved. If the app hasn't added support, it won't save state, it'll just relaunch when you cycle to it, which is the behavior you're observing and mistaking as poor multitasking.
There actually was a reason why backgrounds were not implemented on the 3G. It is apparently too slow for smooth icon animation with a background, and Apple is very picky about the user experience.I was pissed enough to make this, which sums up my feelings on iOS4...
Has Bookworm been updated to support multitasking?
Jailbreak available for both 3g and 3gs. Multitasking and background wallpapers are enabled by default on the 3gs. 3g they turned those features off. With the new version of redsn0w (jailbreaking software) you can enable those features on the 3g. Below is the guide for 3g
http://www.redmondpie.com/how-to-jailbreak-ios-4.0-with-redsn0w-0.9.5b5-3/
Same site has a guide for 3gs as well.
My normal 3G has been running about 20% slower since the update. I like the idea of the folders, but I'm not sure I like the look of how they were implimented.
I really do like the new iPod interface tweaks, though.
The idea of a unified mailbox is pretty cool, but since there are no unified trash/outbox folders it doesn't really help me much.
I get the feeling this update is really much better on a 3GS, or especially on the new iPhone 4.
Whats this i hear about att or apple basucally can locate you when they want on the new os. And you basically agree to it when u upgrade/install the new os
