PAo_ReVoLT
- Apr 4, 2008
just have an idea if watercooled them to 1 slot then put 4 of them on i7 mobo, so is it possible? also on driver side?
thanks
thanks
Hey Kyle,
Crossfire is supported on both 3800 and 4800 Series. And 4x 4890’s are indeed feasible and supported by our driver if the motherboard has the correct PCIe lane spacing and the end user can find a power supply for it.
Hope that helps.
Regards,
Jay Marsden
Public Relations Manager
AMD Global Communications
Not a long time back I saw someone using 8 GPU with 4 HD3870X2's, but it was slower than just using 4.
I forget which review site it was, though.
