OK, I was cleaning off the stock thermal compound from my AMD cpu and some of the compound got onto the cpu pin so I cleaned it off with a alcohol wipe I applied some AS5 and put my heatsink in place and waited the the stuff to dry. When I turned on the pc, the moniter stayed blank, there was no beep, the fans were spinning, and there was a horrible burned smell so I turned the pc off. I took out the cpu and reapplied the AS5 and just left it to dry so I can try again today. Did I destroy my mobo or did I just mess everything up?
