I know this sounds silly but a friend of mine insists that Optical out to a receiver yields better sound than the S/PDIF out. I told him both of them are digital out connectors and all they do is passing over the signals so unless the opical and coaxial cables are of much quality difference, they should really sound the same from the receiver....what do you think? Did anyone compare the two side by side?
Take Audigy2 for instance, the standard Audigy2 only has the S/PDIF out while Audigy2 Pro/Platinum has both Optical and the coaxial. Will outputting the signals from a standard Audigy2 via S/PDIF out to a receiver sound the same as outputting the same source to the same receiver by using the optical out on an Audigy Pro/Platinum?
