OK, so I just built this rig:
s754 3000+
512mb pc3200
Geforce 6800nu
80gb 7200rpm IDE hd
52x cdrom
3x 80mm fans
First I built it with a 420w Enermax Noisetaker (dual 12v rails), but when I would try to install Windows, it would just turn off. Right about at the point where it says to hit enter if you'd like to continue to install Windows. Totally baffled at this point, I tried a new PSU, a 400w Antec Smartpower 2.0 . This let me install Windows, but I've still had the computer power down a few times at random. The last time was during the CPU test of 3dmark05. I already ran 3dmark successfully a few times, but during the last one it just turned off. I wasn't even sitting at the computer.
Does this seem like a PSU issue? The Enermax has higher ratings across the board than the Antec, but the Antec "almost" fixed it. And if it is a PSU issue, how much freaking power would I need to power this fairly moderate system?
edit: OK, here's the update. It's turning off during the same part of 3dmark every single time now. It ran successfully before, but that was before I installed necessary XP updates, including SP2. It turned off a few times before SP2, so I know that's not it. I had to install hte updates because I was getting a 3dmark score of 989, which is about 3000 short. 3dmark is running better now, so I know the Windows updates are why it was failing, and not something related to this crash. I've also unplugged the cdrom drive and the fans and it doesn't change anything, but I doubt they were drawing that much power to begin with.
s754 3000+
512mb pc3200
Geforce 6800nu
80gb 7200rpm IDE hd
52x cdrom
3x 80mm fans
