I'm a little new to this so bear with me - I'll try to explain it best I can.
Basically, I'm trying hook up both my ASUS VE276Q monitor and Toshiba 40E200U TV to my ATI 6950 card. My ASUS monitor is hooked up via dual link DVI-D cable, and the Toshiba is hooked up via D-sub cable+DVI adapter.
The issue I'm having is that I cannot set the TV's resolution to 1920x1080. The maximum it will let me set it to is 1360x768. So instead of the VGA cable, I tried hooking it up with HDMI . This fixed the resolution problem. However, the second I plug in the HDMI cable it forcefully disables my ASUS monitor. When I try to go re-enable it, it gives me the error message "Unable to save display settings". Does anyone know what I'm doing wrong here?
