boxterduke
- Oct 20, 2006
Hey guys, I started having this issue with my HTPC this past weekend.
It has been working fine since I set it up a year ago.
The PC is a Dell
Windows XP SP3
P4 3gig
1.5 gig ram
Asus ATI AH3450 (AGP)
Sound is onboard
TV Sony KDL46W4100
Sound from TV is connected to the Sony home theater in a box through optical cable.
Connection of PC to TV is as follows.
DVI to HDMI (connected on HDMI 4)
Using the RCA audio connection on HDMI 4 to connect the sound.
So the sound goes from the mini jack of the PC to a mini-to-RCA cable to the RCA connection at the back of the TV that is on
HDMI4.
Since last week, the issue is intermittent. No sound sometimes comes out. If I switch to cable TV or PS3 the sound is fine but I
go back to PC and no sound. The weird this is that sometimes the sound would come out when windows is logging in but then when no
sound after that. Also sometimes the sound would come out just fine. I would watch movies for a whole night and then once done,
turn off the PC and then the next day it would stop working or it would work and then if I restart the PC, it stops working. Very
intermittent.
I tested by using external speakers and they worked fine.
I plugged in the audio from the PC to the home theater in a box instead of the TV and that worked fine.
I tested the RCA plugs that are with HDMI4 alone using the satellite and the sound came as well.
I used component video cable with the RCA from the TV connecting to component in and the sound came fine, I switched right a way
to HDMI4 and RCA audio to HDMI4 and no sound.
It is only when connecting the PC to the TV on HDMI 4. I noticed that the video card might be trying to pass the sound though
HDMI. But since it is DVI to HDMI no sound is coming out. (I know that no sound comes out when DVI to HDMI). I also used the TV
speakers instead of the sound system and it did not work as well.
I uninstalled the video card drivers and CCC and when restarting the sound came out fine. So I started thinking that the video
card is trying to pass the sound using the HDMI audio driver and blocking the sound coming out from the onboard audio when it is
connected to HDMI4.
I reinstalled using custom options and I did not pick the option to install HDMI audio driver. But when restarting, it was
installed. I checked it by going to control panel and then sounds and looked at the devices tab and found that it is listed there
as possible devices to use for playback. I disabled it and restarted but the sound still does not come out.
Any ideas? Is there a way to force disable the sound from HDMI and just use the onboard sound? I want to use HDMI4 since it has
RCA connection that saves me from having to switch the inputs on the receiver.
I think I narrowed out what the issue is I just need to see if anyone had this issue before and what they did to remedy it. Or if
anyone knows how to force sound through the onboard audio and stop the video card from trying to pass the sound instead. I think
the digital signal from HDMI is winning over the analog from the on board sound.
Hope I made this clear, if you guys want me to clear it more let me know.
The PC is a Dell
Windows XP SP3
P4 3gig
1.5 gig ram
Sound is onboard
TV Sony KDL46W4100
HDMI4.
intermittent.
connected to HDMI4.
