I'm a little paranoid right now on loosing some music I bought. I have a downloads folder where for the last several months I've downloaded music to from amazon.com. Typically, after the download, I would import the file into iTunes. Apparently, iTunes only referenced the location of the mp3s and didn't import it into it's own music itunes folder.
Well, without knowing that, I was doing some cleanup on my pc this afternoon and deleted a bunch of files that have accumulated in that download folder. I thought I could delete these music files since i had imported them to itunes... no need to have the same file in two locations. Well, now i loaded up itunes and see all these exclamation marks next to my music and itunes claiming it can't find the files. All these missing music files are still on my ipod touch 4g. What will happen when I sync? Will they be removed from the ipod since they are not found on the pc itunes library anymore? Will they be copied over and restore the original locations on my pc? I'm dreading the thought of loosing all this music that at $0.99 - 1.50 each will add up... I think I've bought about 80-90 songs from amazon that I'd hate to loose.
Please, any tips or suggestions or sympathetic understanding would be greatly appreciated.
