frankhuzzah
- Apr 18, 2007
I recentely put together a new build in a Node 304 case. So far I'm very happy with it, except the CPU temps seem a bit high. I'm not overclocking and am using the stock cooler, but they still seem to idle around 40C and were maxing in the upper 80s while playing Bioshock Infinite. The GPU seems to stay rock solid at 30C idle and 60C while gaming.
Part of the issue is that the PC sits in my media cabinet, which is wide open on the front, but closed on the back. This was causing the temps around the case to be around 95F. I switched the directions of the case fans so that the rear fan is intaking and its exhausting out the front, and this has helped some. About 45 minutes of Bioshock and the cabinet was staying around 77F and the CPU was hovering around 78C.
I know these temps are 'ok', but I'd like to try to improve things so that it doesn't sound like a jet when gaming. Would I get better results from adding a fan to my media console to try and get some of that hot air out of there? Or would it be better to upgrade the CPU cooler to better dissipate that heat?
For coolers, I'm debating between the Thermalright AXP-100 or a True Spirit 120m (or equivellant). The tower cooler would need to be turned 90 degrees to get on the ITX board with a graphics card.
My specs:
Node 304
Intel i5 3470
Sapphire 7870 XT
Any suggestions or opinions would be greatly appreciated.
My specs:
Node 304
Intel i5 3470
Sapphire 7870 XT
