I wrote this program on my laptop while I was on labor day break. Now I transfered it over to my main machine and it doesn't work. The part of the program that is crashing out, is when I load the jasperReports xml file to compile it. I'm geting this error.
The xml files are in the right place, they are the same files, and they are properly conformed. Any ideas?
Code:
WARNING: Parse Warning Error at line 1 column 0: URI was not reported to parser for entity [document]
org.xml.sax.SAXParseException: URI was not reported to parser for entity [document]
