Hey, I have a few quick questions about some options in the Bios of my Jetway A210GDMS. First off, in the Miscellaneous Control, what does the overvoltage option do? It only has an enable or disable and the CPU/VRAM Voltages don't seem to be effected by this. Should I leave it enabled or disable it? Also under the Integrated Peripherals -> On Chip Device Function -> South Bridge Feature there are options for P2P Pre-fetch Queue Depth, P2P Maximum Pre-Fetch DW, PCI/14m/USB CLK Powerdown, S.B. PCI-E Performance, and ULI HPET. Anyone have any clue what any of these options do? I've googled them and come up with nothing. I'm particularly interested in the SB PCI-I Performance and the ULI Hpet... thanks!
