Hi all, just wanted to know if this jigsaw would be good to get. I found it for $20 canadian, and I included the specs below. Is it a good one for cutting side panelles for adding plexiglass mods? Thanks for any suggestions
3A motor with 2 speeds: 2,000 and 3,000 spm
Base adjusts from 0-45° for bevel cuts
Plexiglass blade guard/sawdust deflector
Universal blade holder
Lock-on button for continuous use
Cutting capacity: 2-13/64" (55mm) in wood and 3/16" (5mm) in steel
Weight: 4 lbs 6 oz (2 kg)
