96redformula
- Oct 29, 2005
I love this PSU, fan still does not kick on at full load with 2 7950's at full load mining(I don't think its getting warm enough), but I am a bit concerned. [H] Did a review on the modular 550w version at 650watt even though it is "rated" at 550W and it didn't seem to phase it much at all. My Kill-a-watt meter is showing 570Watts being pulled from the wall while it is mining. It seems like they marketing it at 550w to meet the platinum more so than do a higher wattage lower efficiency...
I didn't have intentions of going crossfire or two cards and it was the only PSU I could find that was platinum and ran fanless. I did remove the case panels on the SG09 for now and set it on its side to let it vent completely. Should I underclocking CPU to try and lower the wattage pull or do you feel I am okay(It will be on full load mining)?
Intel i5 3770k
4GB Ram
Corsair SSD
Samsung 1TB HD
(2) AMD HD7950, powerboosted
Intel i5 3770k
4GB Ram
Corsair SSD
Samsung 1TB HD
