Chris Lakies
- Feb 17, 2005
I have the Lanparty NF4 SLI DR mobo and have a cpu cooler that i can put 2 fans on (one pushing the other pulling.
I would like both fans to be controled with the on board 3 pin connector.
I've seen splitters (1 to 2) for the 3 pin power connectors and was wondering if one of those 3 pin CPU fan contolers could feed enough power to both fans without burning up?
Also should I put the highest CFM out-put fan pushing or pulling?
Update: I just saw that the fan I bought has a ATX connector that I can power direct from my PSU. It also can be controled by the mobo controler because it has the 3 pin - one wire (yellow) control wire. YAY!!!! I will use the splitter for that.
