Providence
- Apr 23, 2006
Hello--
I'm fairly familiar with PC HD data transfering, but I've got a laptop that's nearly dead. I think if I mount it as a slave drive, I can probably transfer the files I need. Usually works on nearly-dead full-size drives.
The only problem is I have no idea what kind of connection the Inspiron 1000 takes, since it's definately not SATA or IDE...I can't just plug it into my computer! Does anyone know what this is, and if I can get a USB adapter or something so I can get my files?
Thanks if you can help!
