I'm not sure if this will help, but the model is Compaq Presario R3000. As I write this, the laptop is running terribly high at 77 degrees C. This seems very high, since I'm only running Firefox and Everest in the background. Just before, I believe it overheated since it shut down while I was playing Counter-Strike. Is there anyway to decrease the temperature on the laptop? It's currently sitting on a desk, and it's not like it's very hot inside the room at the moment. I did some research and apparently the AMD Athlon 3200+ mobile edition is designed to reach temperatures up to 95 degrees C. This sudden turning off of the laptop has only starting occuring fairly recently. Could it possibly need a reformat, are some of the hardware parts getting faulty? There is no longer a warranty on this thing, so I'm out of luck there if it is a big problem.
