Hello,
I have been contemplating building a HTPC based off of the AMD E-350 platform. My pricing out is roughly $350 depending on case / hard drive I use. I also see that there are Zotac boxes that are effectively the same price. Then I also saw this:
[ame="http://www.amazon.com/Acer-LX-RD502-005-AS5253-BZ602-15-6-Inch-Laptop/dp/B004ETLO6C/ref=sr_1_1?s=electronics&ie=UTF8&qid=1308103037&sr=1-1"]Amazon.com: Acer AS5253-BZ602 15.6-Inch Laptop: Electronics@@AMEPARAM@@http://ecx.images-amazon.com/images/I/31oXbvgqxDL.@@AMEPARAM@@31oXbvgqxDL[/ame]
which seems to have all the same features of a HTPC (and I would add another 2 GB of ram).
What is the benefit of building a HTPC box or buying a zotac box (like this one)
http://www.newegg.com/Product/Product.aspx?Item=N82E16856173022&cm_re=zotac_e-350-_-56-173-022-_-Product
over the laptop I posted. Seems like, spec-wise its almost the same, but I would get the benefit of a screen and portability over the HTPC. I guess I lose a few USB ports. On the other hand, I plan on keeping it for the most part inside a cabinet next to my tv. Heat is a concern of mine, would the laptop potentially run hotter?
It just seems like, for roughly the same price (give or take $25-50) I would get a device with more options.
Any thoughts? is these something major I am missing?
