hi-
i was wiring a series of 4 LEDs into my psu, and i was planning on using the wires that power the fan. ( 3V each... 3+3+3+3=12V ) but then i started wondering... the fan is thermally controlled, so it slows down as the temp drops, and speeds up as the temp rises... does it supply the fan with less or more voltage to do this? if i wire the leds to it, will the LEDs dim and brighten with the temperature changes?
thanks in advance!
thanks in advance!
