Think i should upgrade it to vista or just leave XP pro?
Thats a pretty ignorant comment.. Vista is quite stable, actually..I'd keep XP on that rig, Vista will be boggy.
On a system like that it would be a toss up which would perform better. If you up'd the ram and added a usb 2.0 flash drive you'd probably see Vista faster than XP. Otherwise, I'd definitely stick with XP...
I have a feeling you either a) didn't read my post properly or b) are a moron.
I said on that system Vista would be boggy, and probably not as enjoyable as XP would be for her daily use. Please read before talkin shit, I never once commented on Vista's stability whatsoever.
that should be a great little box. SMP + 1gb of ram will make it run beautifully. I have a dual 800mhz P3 (non xeon version) + 768mb of ram box that I run here and it works great for all normal functions.
Don't underestimate older hardware
How about some sandra benchmarks?
