One could always order one from USA...Tamlin_WSGF said:Too bad the NEC 24" s-ips doesn't hit europe
peTeMelster said:What Nec 24 and 26" are you guys talking about?
sure and what about warranty or if it has bad pixels.kenpas said:One could always order one from USA...
However, someone on anandtech posted that monitor actually uses the same panel as the BenQ FP241W (P-MVA) -- though I had heard that the panel was actually some type of *VA variant, I hadn't seen any specific info about the panel model, so I'm not sure where the source for his info is. Also, does anyone know what "Anti-glare, Hard coating" finish means? Is this a "glossy" screen?178/178 (S-IPS) Ultra Wide Viewing Angle
You're sure it's S-PVA and not the P-MVA by AU Optronics used in the BenQ? Did they give you the specific manufacturer and model? Thanks.I spoke to LG directly and the 24 inch will be using an S-PVA panel. Same as all the other 24 inchers
Looking at the angle screen shots in that review, I would say that is a VA screen, not a S-IPS screen. Quite bad loss of contrast at angle. Either it is VA or the figured out how to really make S-IPS suck. Looking around I can't find anything at all from LG on this. This is not a S-IPS panel IMO.
BTW it would not be the first time people thought LG - S-IPS when it was really VA. Does LG indicate S-IPS or is that an assumption this time? Here I think even LG was mixed up:
http://www.behardware.com/articles/598-6/20-inches-lcd-p-mva-vs-s-ips.html
Thanks very much for this info. Does anyone know if there's a translation tool that will let me read the interview? I assume it's in Czech? I'd like to know the overall reactions to this monitor. Has anyone found any other reviews besides the Polish one posted earlier?Hello, one Czech hardware site has a review of L245WP with a photograph which clearly shows the panel AUO M240UW01 V0 [1], which is P-MVA (used in BenQ's FP241 models). Unfortunately the author still claims the monitor has A-MVA, but it's not true - A-MVA panel is M240UW01 V2, according to AUO website [2].
[1] LG L245WP Review (page 2)
http://www.svethardware.cz/art_doc-D1E351F88390DA00C125727000681DC2.html
[2] AUO M240UW01 V2
http://www.auo.com/auoDEV/products.php?sec=monitor&func=info&product_id=6&items_id=1
Thanks for taking the time to do this! The overall tone seems to be pretty negative, but I wonder how much of this stems from the mistaken belief that this uses a new panel. The real question is how this compares to other models on the market -- for me, the only real negatives on that list would be the "bright shadow" (not sure what this means -- inverse color ghosting?), and the low backlight score (light leakage? bad uniformity?).Unfortunately, I don't know any cs-en web translation tool, but I can provide you a little summary:
- Measured response time was 17.8 ms rise and 8.8 ms fall with 20% overshoot which caused notable bright shadow,
- There is a problem with brightness settings in custom color temperature modes - monitor switches from hardware to software adjustment,
- The score for backlight was not too god,
- Interpolation is only average,
- There is no DVI connector (included is HDMI -> DVI cable)
The overall score was less than HP LP2465. Unfortunately, the author still thinks that the technology is A-MVA and compares it against S-PVA, which makes most of his opinions a little bit wrong.
Someone on Anandtech emailed LG directly and was told that this monitor only uses P-MVA, not IPS. This seems consistent with what other reviews have been saying, so I don't think there's much hope that this will be an IPS panel. I noticed NCIX said IPS when they first put up the page, but I think that was just copied from other out-of-date descriptions that LG had (maybe still has?) on their own website.904 Cdn (with a S-IPS) panel and the price will be lower soon according them (NCIX)
http://forum.ncix.com/forums/index....did=1288582&pagenumber=1&msgcount=6&subpage=1
Emailing them and asking,got me a tech saying it uses different panels(P-MVA /S-IPS.and another)
I'd also be very interested in reviews if anyone has or is planning on buying this.Any one have one of these yet? Would love to see a review.
What kind of anti-glare coating does it have? I recall from an early review it had a glossier finish than most. Does it come with a DVI/HDMI converter?
NCIX has it on sale for $799 (reg. $849) for the next day or two... http://www.ncix.com/products/index.php?sku=23000&vpn=L245WP-BN&manufacture=LG Electronics
says is 178/178 (S-IPS) Ultra Wide Viewing Angle.
Please tell us what site, so that we can add it to our list of un-credible sources.
Heh, they still haven't changed this? It's well known that this monitor uses a P-MVA panel, the same as in the BenQ FP241W. LG themselves confirmed this to someone on the anandtech forums. I suppose they were originally planning to use an IPS panel but then changed their minds and still haven't updated the website.LG's site actually says it is:
http://us.lge.com/products/model/detail/commercial_lcd monitors_20 inch and above_L245WP-BN.jhtml
Hi,
I would be very interested in "Input Lag" of this screen. Specifically, how many milliseconds delay versus a clone CRT displaying identical sources such as virtual stopwatch.
My quest for 1920x1200, 8-bit pixels, low response time AND no-input-lag continues!
The 23" Apple Cinema Display is all of that, and it's S-IPS.DMP said:My quest for 1920x1200, 8-bit pixels, low response time AND no-input-lag continues!
