Hey,
Does anyone know the specs for a 120mm Lian Li case fan?
The one that came with my new case is pretty loud... what would you recommend as a replacement?
Actually, I switched it from the molex to mobo and it quieted down significantly.
I should be all set. Thanks guys!
