Punx_Clever
- Jan 10, 2005
Hey, I was wondering if anyone has had any luck with putting a 120mm fan on the removable mobo tray on this case.
Thanks for your help.
lemons said:I did the rear 120mm fan thing. doesn't look to bad. Did it knowing that I'm getting a new case soon though, so it didn't matter how it turned out.
http://www.hardforum.com/showthread.php?t=865678
The drive cage is rivited to the bottom of the case so can be drilled out and them bolted or riveted wherever you want.
yeh, both. Fans are running on 5 volt so very quiet and still seem to blow enough cool air.Looks good to me lemon. Were you going for high airflow or low noise?...mixture of both perhaps?
Punx_Clever said:Lemons, that looks like it would work just dandy for what I'm doingon (the rear fan thing). Thanks a bunch. I'm upgrading my case from a Cheiftek dragon to something in aluminum and wanted my radiator in the back (shortest tubing setup) so I needed a 120mm fan there. Thanks a bunch for showin me that it'l work.
